**NVIDIA GTX 480 IS BACK - TRULY INCREDIBLE PRE-ORDER DEAL!**
This card is the best bang for buck on the market at the moment, I don't understand why some would claim otherwise with the current prices in the UK.
The only alternative to this is a 7850 if you can't cope with the heat output and power consumption of the GTX 480 or game at a very high resolution (when VRAM may be a deciding factor).
It will still be a faster card when both are overclocked but I understand why some might choose the 7850 over it.
This.:)
Yeah in some games it may trail behind by 1 - 5 fps, but remember the 7950 2GB is running those fps without the need for ear muffs or water cooling to stop the card burning. Like I said before I will agree to disagree..
I'm enjoying my 480 SLI laying waste to BF3 at 100+ fps, without any nonsense crossfire issues :cool:
Why on earth should it bother me how hot they are? If they work its frankly a bizzare thing to worry about.
Very true mate.
If your rig can handle the gpu cooling/exhausts/psu that's required then 480 is the only card to buy!
On the other hand if you have a small factor pc that 'heat is the enemy' then the 7850 would be far more suitable to prevent meltdown, the 480 is a bad choice in this case due to the even higher temps/stress on the 480/system.
Very true mate.
I agree, although speaking as a M-ITX user, the heat problem is largely dependant on your chassis.
I built my latest system using the Silverstone SG07 and I've no heat problems at all. The GPU is situated right next to a well ventilated side panel.
I am running a GTX 470, which has no problem in the chassis. I've even seen people get a GTX 590 into the chassis with it's standard PSU and have no real problems.
So the GTX 480 is still a brilliant card to get, especially at it's current price.
Kepler will probably bring an epic card for this kind of money ;-)
'A fool and his money are soon parted'
When Kepler comes out, if it's faster it will be pricier. It will be a while (say 6 months) before prices hit the levels where you get a card like this for this price. If you're waiting 6 months, you either don't need the card or you're willign to wait 6 extra months indefinitely. There will always be better deals.
Oh goody a synthetic benchmark. You forgot to overclock the 480 BTW.
This is one hell of an overclock - 2600k @ 5.7GHz?!! wow...
Ok mate just for you the few others still in denial let's do a comparison :-D.
We all know the GTX 570 is a tiny bit faster and more refined than the GTX 480. see GTX 570 VS GTX 480 here, http://www.anandtech.com/bench/Product/309?vs=306 The 570 edges the 480.
Now let's compare the HD 7850 VS GTX 570 as you can't compare the HD 7850 to the 480 as the 480 is to old, it's not on the list.
So here we go, GTX 570 VS HD 7850
http://www.anandtech.com/bench/Product/518?vs=549
Crysis warhead HD 7850 wins
Metro 2033 Draw
DiRt 3 GTX 570 wins
Total War Shogun 2 HD 7850 wins
Batman Arkham City GTX 570 wins
BF3 GTX 570 wins
Starcraft II HD 7850 wins
Skyrim HD 7850 wins
Civ 5 GTX 570 wins
3D Mark vantage HD 7850 wins
DX11 Tessaltion HD 7850 wins
Unigine GTX 570 wins
So HD 7850 wins 6 and GTX 570 wins 5, also do try to remember the 570 is faster than the GTX 480. Now I know this will be hard to swallow and no doubt loads of flaming will start now, but fact is HD 7850 is a better card than the GTX 480..
Oh yeah we know HD 7850 also wins in 3D mark 11 against the GTX 480 and obviously more memory, lower power consumption and less heat help for better overclocks. The HD 7850 overclockes very well, without need for extra water cooling etc...
Let the flaming and trolling commence! :)
Being completely neutral, this is how I read the Anandtech comparison.
Crysis - 7850 wins
Metro - Draw
Dirt 3 - 570 wins
Shogun - Draw
Batman - 570 wins
Portal 2 - 570 wins
BF3 - 570 wins
Starcraft 2 - 7850 wins
Skyrim - 570 wins
Civ 5 - 570 wins
10 games benched and 570 wins 6...7850 wins 2...tied 2
Just my tuppence worth. I just want best info.
So all of sudden it seems tessellation benchmarks are not important any more? A year ago it was all the rage on these forums to determine if a graphics card was good or not.
How times change.
Boomstick777;21411640 So here we go said:
http://www.anandtech.com/bench/Product/518?vs=549[/URL]
Metro 2033 Draw
DiRt 3 GTX 570 wins
BF3 GTX 570 wins
Skyrim HD 7850 wins
Civ 5 GTX 570 wins
To be objective you have to take more than one review.
Here's some from Canucks and Guru 3D.
http://www.hardwarecanucks.com/foru...2165-amd-radeon-hd-7870-hd-7850-review-9.html
http://www.guru3d.com/article/amd-radeon-hd-7850-and-7870-review/12
At the moment for the money the GTX 480 is stilla brilliant card.
There are more sites, and as such I suggest anyone including yourself look at all of them. Then make a choice.
I have owned 4 diffrent 480's and i can tell you as long as there in a case with good airflow there are quite and run cool even when over clocked to 850 on the core and upping the volts
Also the 480's scale very well when overclocked which pushes them past 570 performance and and to stock 580 performance and at £185 there is no other gpu with the same Bang per buck...
This + if you do any 3D rendering in Blender or any rendering engine with CUDA support then the GTX480 is a great choice, you'll not find another card with 480 CUDA cores for £185.
It's clearly a winner all round :)
