****Show Us The inside of your Case!****
1 thing I would say is the side panel could do with an extra 3-5mm of depth.
Getting it on without a bulge was a dark art!
Cheers :) It was only supposed to be a temporary build until my watercooling parts arrived, but its grown on me :confused: Might leave it as it is for a while
It does look very nice I must say, that cooler fits in very well. Are the SLI temps okay?
Indeed. :D As I said around 22*c off load temps, highest I've seen it at is 48*c. (OC to 875/1750 2000)
That is impressive, you wanted seriously cool then? Mine gets to around 60 under load.
I'd love to show you guys my current set up, but i've not touched it for 4 years, so you'll have to wait for my case mod log for the Fractual Design Mini. :)
Never got around to watercooling this. Its the rev.1 of Mountain Mods Bobslay. Nice design, but the build was poor and things didn't really fit together as well as they should for a £160 case. I got the clear case and custom sprayed it smokey black. Again, didn't work as well as having smokey black perspex but things has moved a lot since getting it. The rig has served me well and useful and LANs.
EDIT: Oh hang on found some old pics..
Post it anyway. I posted my old case a few pages back; broken fans, dust everywhere, supposedly clear watercooling fluid looking like tea, wires snaking all over the case, radiator pretty much nailed to the back of the case, etc.
Seeing a picture of it spurred me on to get a new case and some upgrades. :p
The temp on the left is coming from chiller and the right is once through the loop...very occasionally the left temps are higher than the right but mostly right is 1 deg ish higher.
DO you not get any condensation issues with those temps? Can't remember what the average dew temperature is, but you can't be far off it, if not already past?
yeah ive had it twice....once when i had it set to 10c so i brought it back to 12c which stopped it but ive had it at 12c aswell...if im 10c lower than ambient im ok but after that its a lottery....
summer will be fun :) its worth it though
Watercooled pc.. Ocd wiring.. by http://www.samcatchesides.com/, on Flickr
Not finished on the wiring yet (not neat enough), and the lighting is the next project... Full custom diy RGB led system... :D
The res mounting is temporary until its been redrained and refilled.. Tie wrap isnt really a great permanent solution.
And the Dynamat thats visible will be trimmed and removed so its not visible on the back of the other case half...
Going to get it into the studio once its finished and get some proper photos..
Sam
