Likely MB/s on Gigabyte network?
Permabanned
15 Nov 2011
Im getting the following speeds below but tempted to change my set up which will allow gigabit speeds/conection. Just wandering what that turn out to be within W7 under a file transfer....
Thinking of upgraiding to a TL-WR1043ND http://www.tp-link.com/en/products/details/?model=TL-WR1043ND
My NAS can then plug directly into that and it can also be a ''switch'' as and when im wired in!
I coppied the Top Gear S18 folder which has the 1st 3 EP's that I have pulled in HD off BBC iPlayer service DRM Free :), 3.44GB
NAS is WD My WorldBook (white one), router - modem is a Netgear DG834 DGTeam FW and the WIFI AP on this test is a TP-Link TL-WA801ND
DOWNLOAD OFF NAS TO LAPTOP
hosting images
UPLOAD OFF LAPTOP TO NAS
image host
With a decent NAS and Intel NIC's
On a cheap NAS expect 20-40MB/s
My gigabit network will transfer files at speeds like Zarf's image.
I have a pair of raided 1.5gb drives in my shuttle under the TV and an SSD and two raided 500gb drives in my PC. It's nice having a gigabit network as my bottleneck :D
I've occasionally seen marginally above 120 which is impressive as I would have thought there would be overhead stopping that.
Network speeds aside, you are transferring files over Wireless and as such you'll be unlikely to see a massive benefit over what you're managing at the moment.
I was able to link directly to my NAS, didn't know i could but anyway here are the results :( but then again it's a WD My world Book (white light)
GIG DOWN SPEEDS
GIG UP SPEEDS
I've noticed that the transfer speed of any mbit/gbit connections are huuuugely dependant on your router unfortunately.
The above was done with the WD Mywoldbook pluged directly to the laptops gigabit port! CAT6E cable, 1M in length, latest drivers for the NIC. Jumbro frames set to max (9000 or 900 i forget).
A decent proper NAS will help and is what im going to do
Port to port that does seem quite slow, USB2 speeds tbh :(
LOL pryopete and the file name does not point to anything untoward at all!
Theory says you should get better speeds but it depends on your access point and the speed of your NAS
Nope, it's how you obtain them that begs the question! Having them doesn't!!!
AP...? NO AP present. Just a 1M CAT 6 from laptop to NAS
