If you go by that image it shows the GK104 it to be somewhere around the 660ti/670 area and due out somewhere around the middle of the year.
GK110 on that chart has 2 384bit buses, that would imply it's just a dual GPU card.
And the GK112 is the proper high end and touted for 2013...
Is that an official chart?
This is another post from the HC reviewer on XS:
http://www.xtremesystems.org/forums...orce-GTX-780&p=5069322&viewfull=1#post5069322
So,maybe the 25% improvement in games performance over an HD7970 3GB mentioned earlier in that thread is true?? He seems to be hinting this.
It would make the GTX680 around 36% faster(as I suggested earlier if HC review figures are used) than a GTX580.
Edit!!
I wonder if he has considered the HD7800 series against the HD7900 series though as the former seems more efficient relative to its performance.
I will be quite shocked if its 25% faster than a 7970 across the board. It will be interesting to see how it competes with a 7970 running at 1200Mhz.
It's all well and good saying it's faster but what applications are they using? What games and what settings also what resolutions.
If they do have a stonker of a card that beats the 7970 by 25% they would price accordingly or is price matching they're way of winning this quarter?![]()
This is also a factor to be considered. The 7970/50 clock very well and can't remember the boost it gives from stock? (maybe 15% but dont quote me).
Anyways, if the 680 has been pushed on stock, it will be interesting to see if the OC on this is any good, or just negligible. This for me holds the key.
I dont mind if it is on par with the 7970 and clocks like the 7970 and they charge the same as the 7970 (Gibbo hinted at this).
Purely for my laziness I will get one. (saves me having to swap out drivers etc etc)
Yeah I didn't get that either.
For a brand new architecture it's doing a lot better than Fermi did when it reared it's ugly head.
So when they come up with a revised version of GCN, it will be (as he says) 2nd generation and rather good.
The 7870 is a really good looking card, I didn't expect it to perform that well.
Edit - If the 660Ti is as efficient as the 7870 it would be great competition and much much cheaper than their flagships and earn both companies a lot of sales.
True,but also consider the relative performance of the HD7870 when compared to the HD7970 and HD7950 at 1920X1080,considering that Tahiti has 54% more transistors than Pitcairn and has a 72% larger surface area for the GPU die.
I was going on ocuk prices for the saphire.
This is the cheapest i've seen on ocuk
http://www.overclockers.co.uk/showproduct.php?prodid=GX-206-XF&groupid=701&catid=56&subcat=938
Don't quote me but I believe the 7870 is a 7970 with the GPGPU capabilities stripped down.
