Obviously it gets checked first to see if it needs adjusting.
So you get it checked, they tell you that the rear allignment is out and you.. decline it? Or what?
Why don't you take an educated guess.[TW]Fox;21482256 said:So you get it checked, they tell you that the rear allignment is out and you.. decline it? Or what?
[TW]Fox;21482404 said:I've no idea what you are waffling about now.
First you tell us you never bother with allignment you just get the tracking done. Then you say that obviously you get the allignment checked when you have tyres. Then you get all sarcastic when I ask what you do if you are told its out at the back?![]()
From what Phate was saying, he's going for a full geometry set up. I dont bother getting that done, I just get the alignment/tracking checked and if need be, get it adjusted. The only time I get a geo set up is when I buy the car. I hope that makes more sense, I reread and concur that my previous posts were quite confusing.
[TW]Fox;21482461 said:I think what Phate is actually going for is what you normally get. Not a full custom geo setup but just getting the camber/toe adjusted back to manufacturers specs if they are out, and left alone if they are not![]()
Considering alignment and 'geo' are one and the same, it doesn't make much sense. Put the car on the rig, get a reading, fix whatever is out of spec, that's normally how it works isn't it. Unless it's some kind of ghetto alignment system that's in use.
[TW]Fox;21482536 said:He's talking about people who pay Wheels In Motion eleventybillion pounds to do a custom setup.
Just make sure you're not paying £100 if only the front toe is adjustable![]()
I don't know if its only front toe adjustable, and quite frankly, I don't particularly care.
I go there, they take a look at my car, tell me where its out, if at all, if it is, they fix it and I pay them moneys.
JOB DONE.
JOB DONE.
Front toe adjustment does literally cost £10 in most places, so for £100 I am expecting a full set up and adjustment with a print out after. You should find out before handing over £100.
