At a 706 Mhz core if it scores 1362 on heaven then at 1006 Mhz it should score 1940.
Yes, which would make it VERY impressive....but like I said, I think we need more info from the possessor of this card!
111 points more than a 580? something is iffy with this. At least I hope so anyway.
Well the 660 on which it's based is the replacment for the 570, so it's not really surprising really. Unless the person benching has deliberately clocked the card down to 700mhz, or that is the actual clock. Until we see official reviews from official channels it's all still open to interpretation depending on which way your willy faces.
If that benchmark is for real then his CPU is really really holding him back - or something - at that point after the benchmark finishes with that kinda score the fps top right should be atleast double that number - tho that not a reliable metric as random things could be pulling the fps low or his PC could be really slow at recovering after reloading after the benchmark.
Also not tried 300.6x drivers but pretty sure they don't have GK104 in the GPU ID string.
With those settings a GTX680 should be getting a ~80fps.
Surely heaven isn't that CPU limited? It's looking like Kepler failing against the 7970 at the mo (based on one dodgy benchmark)
New Green card on Thursday is faster and supports 4 monitors out the box.![]()
Somebody is going to be posting i3 and 7970 benches soon (clock for clock and stock for stock). Either myself or another member.
Once the thread is started up for it, I'll edit the OP with a link to the comparison if its okay with ironman86.
Stock GTX680 i3
snip
Added optional GPU-Z installer which launches when GPU-Z is started for the first time, or can be started manually via the GPU-Z system menu
Added support for AMD Radeon HD 7870, HD 7850, HD 7670M, FireStream 9370, FirePro V3900
Added support for NVIDIA GeForce GTX 680, GT 640M, GTX 560 SE, GT 550M, GeForce 510, NVS 2100M
Fixed clocks not showing correctly on some systems with Catalyst 12.2
Fixed board id reading on pre-Fermi cards
Fixed OpenCL detection for ATI Fusion (Sumo & Ontario)
Fixed GPU-Z window getting cut off at certain DPI settings
I700mhz is probably just a low power state, like my sandy bridge shows 1.6ghz on cpuz.
Stock 7970 i7 with 2 cores disabled at stock speed 3.4ghz (best I could do!)
Not going to bother with the overclocked results as they were at least 10fps more
This is my air cooled windforce 7970 1285 gpu 1750 memory. 1 card 1.25 volts.
Uploaded with ImageShack.us
First benchies from the guy in the shop with one.
(For comparison I get 48 at these same settings, my 480 runs ~580 speed, his CPU is an I3 but even so I am underwhelmed)
