***Official Unigine Heaven DX11 3.0 Benchmark Scores***
20 Dec 2011
Kent
Totally stock MSI GTX 680s, no overclock at all. Max temps GPU1 79 GPU2 79. Fans 55 both. Simply awesome GPUs, ill read up about O/C then post again.
Approx £900 for two 680's that score less than twice as much as 2x5850's & 1680x1050 that were £90 each, a sound investment if ever I saw one ;)
3 Mar 2009
Hope I have done this right. Xfire 6950's @ 860/1350
GPUz validation http://www.techpowerup.com/gpuz/vpxus/
1680x1050
1920x1080
24 Jun 2009
London
^^ Yup makes it hard to trust any results from AMD users :p unless we can compare the tessellation level via wireframe in the final screenshot :p (tho somewhat academic if theres no noticeable visual difference without micro analysis but thats another story).
Even with all that, all a user has to do is to take screenshot without tess, cut out a the score area and overlay it on the screenshot with tess. Paint is all it takes.
I think the best way is to be a little discerning. Look at clockspeeds and benchmark scores. It can't ever be wildly off for a GPU heavy bench like heaven. If a score at x Mhz varies greatly from another bench at x Mhz, then you know something's up.
28 May 2007
I have had a look through all the 7970 scores and they all seem to add up when you look at the different core speeds. Theres enough around atm too say pretty much that no one is pulling a fast one.
OP
5 Jan 2007
Smallbrook
Scores updated!
If your not included and you've posted above this - then you've missed something in the rules. Common issue is tiny pictures that are unreadable with no link to full size version.
Deleted member 66701
D
