On mine I have
Real time Ratio Changes in OS Enabled
CPU Enhanced Halt (C1E) Disabled
C3/C6 Statue Enabled
CPU EIST Function Disabled
I think its the first option you may be thinking of, not sure what the setting would be for Asus board. This lets mine downclock to 1.6ghz.
I notice that enabling vsync prevents my old GTX580 from whining. Shame it doesn't work on women.My 680 whines a bit generally when V-sync is not used, it's not overly loud but noticeable.
^^^not sure on this(epu power saving mode),havnt tested it,left it disabled
heres what worked for me,speedstep and c1e disabled and cpu downclocked at idle in windows
If it whines I would RMA it. Yes, it can happen, but on a £400+ card it shouldn't happen.
its mostly the psu thats the cause,its electromagnetic interference between the mb's vrm's and the cpu power saving states,they use solid caps now on mb's so it cant be coil vibration
with corsairs quality rma service you might be able to rma the psu for another unit? i would do that first before changing the gpu,even then its hit and miss when finding a psu/mb/gpu combo that produces no noise whatsoever
like i said its totally normal to hear very faint whine in game menus ect but not in the game itself or while watching films listening to music,esp through the speakers and headphones,even moving the mouse around on the screen can produce the noise,thats very bad examples though
atleast it reduces it by turning off speedstep/c1e,it was like my x58 ud5 i had to do the same and it was fine after,i was too tight to spend on a better psu at the time
I can't guarantee it's the gpu but since I installed it that's when the noise started so i'm sure its that (could be PSU but doubt it) Thanks for any help.
It does it when I have chrome and couple of other small applications up.
