thanks, i'll push the files over in the morning and try the update again
Actually here is exactly what you would do (you need android drivers and ADB setup properly on your PC):so any way without wiping?
Download:
Connect your phone to PC and use Windows Explorer to copy the update.zip to your phone.
Do the root exploit:
adb push mempodroid /data/local/tmp/mempodroid
adb shell
$ chmod 777 /data/local/tmp/mempodroid
$ ./data/local/tmp/mempodroid 0xd7f4 0xad4b sh
Now you should have root so you can use cat to copy the update.zip to /cache via the adb shell:
# cat /sdcard/7f97fbc19417.signed-yakju-IMM76D-from-ICL53F.7f97fbc1.zip > /cache/7f97fbc19417.signed-yakju-IMM76D-from-ICL53F.7f97fbc1.zip
Once file copy finishes you reboot to recovery:
# reboot recovery
Now you are in recovery and can select to update to 4.0.4.
what does it mean about 'yakju' ? my build is ICL53F?
yakju is the build that gets updates from google, there is another version that the updates come from samsung not as quickly. along with a few others for different countries.
you can check which you have if you open /system/build.prop it's the ro.product.name
Or goto the about menu.![]()
Hmm, where did you get XXLA2? Did it come down with the OTA?
so anyone in the uk got the OTA in the correct way?
Couldn't wait. Factory image flashed:
