Sorry, the 3 pin plug part. The cable itself is fine.
The writing that says the ampage and such on the label on mine is so faint I can't really make it out clearly :/
Random shutdowns can be the same problem, is your battery flat when you start it back up?
Any usb plug will work - look on ebay for a 5V - 2A usb plug - a good quality one is from a HP touchpad. don't buy a cheap and nasty one.
hp - pricey http://www.ebay.co.uk/itm/HP-Intern...Adaptors_SM&hash=item4cffa2bd99#ht_500wt_1156 . I got mine for £10
cheaper here - http://www.amazon.co.uk/HP-TouchPad-International-Travel-Kit/dp/B0058CZX7U/ref=pd_cp_ce_0
Generic - http://www.ebay.co.uk/itm/APPLE-10W...ccessories&hash=item43ae18356a#ht_1614wt_1396
5v is no good for the TF. It's too low.
the TF can charge from a PC USB output
Charging over USB is ill advised at this point since it'll take somewhere over 16 hours to fully charge the Eee Pad over a standard USB port. ASUS claims this will be fixed with a future software update. I didn't have the time to measure exactly how long a full charge over USB would take; I just measured long enough to know it would be a problem.
power rating in watts is what's important in determining how fast something charges.
I've signed up to Twitter to let them know what I think.They probably couldn't care less, but this tablet is useless to me like this. I don't know why they didn't just roll back to the previous version that was fine.
Hopefully someone will release a Tegra3 tablet soon to rival the TF. I won't be buying Asus again..........except maybe the odd GPU.![]()
After having it for a few weeks its a bad tablet imo, I can see why people go with Ipad's now.
Mine behaves better as I have a custom rom on it but its still not great, will be selling for sure and get a Ipad 3.
Had mine since launch with no problems. The back feels a bit flimsy but no issue.
Over reaction much? Why not just root it back to honeycomb if it bothers you that much?
