*** The Official iPad (Early 2012) Thread ***
Indeed, contact the seller and say it isn't working. With any luck he will be decent about it and sort you out with another.
Try trimming the bottom everso slightly, google image for examples of what you are trying to get to. That should help with alignment.
If you cut it yourself it would be hard getting the seller to replace it unfortunately.
Indeed, too much off the left and not enough off the bottom, doesn't look like it was aligned properly before cutting. It also looks quite scratched. Is that how you got it? I'd complain if you did.
Hi, yes it was scratched but I thought nothing of it, I does look worst in the screen shot I suppose.
Does anyone know if the Apple iPad keyboard dock works with the iPad 3? On the site it only lists the iPad 1 as compatible but reviews say it works with the two as well. Not seen one mention the new one yet
Re: cutting SIM cards, I bought a cutter off Amazon/eBay for about £5/6 and it was worth every penny. Also got some microSIM size adapters. Takes all the chance out of cutting and means no money is wasted on the pre-pay 3GB/3 months SIMs.
That's what I should have done.
I'm typing from my first iPad:)
Heavier that I expected.
Lovely screen. Need to download some photos on it .
Time to look for good and essential apps...mostly some news reading ones that can update on wifi so can read while out with it.
Bought back cover and smart cover.
If anyone is looking for iPads in stock,have a look on play.com
I couldn't hack it.. the bloody dead pixel got on my nerves It was laughing at me and making me think about it in my sleep. Went and changed it today :)
Checked the dead pixel checker twice now and slowly and there are none on the new one.
Does the Ipad 3 have the same GPU as the psp vita? they both have very similar names
I know, took them four months for the 2, not hopeful for it being anytime soon
Judging from the FIFA thread you seem a sensible sort of guy, genuinely what do you need from JB which your so missing?
I've never gone down that root (joke intended) simply because I had enough of stuff just sort of working on android. Is it a similar affair ?
