I'm sorry, what now? 6GB of VRAM? Really?
because everything I can find on t'internet shows it maxing out at about 1.9GB on a 3GB card
If you install the high-res texture patch and enable DX11 with 4xAA, it registers 6GB Vram.
What card does it register 6GB of Vram on?
Basically what I am saying is this. When you disable the paging file and run BF3 you do so purely based on the vram you have on your GPU. If that vram runs out (which it didn't for me, and it wouldn't either unless it uses more than 3gb at peak) then it begins to use the percentage it has allocated in your paging file.
	For every game I play I set the Disable Desktop Composition/Disable Visual Themes flags on the .exe Properties Compatibility tab. Even in Windows 7 that is an extra 150MB of VRAM saved right there.
It turns Aero On/off quickly and painlessly automatically no matter where I launch the game from.
7970, 2560x1440, 4xAA, DX11+pack, Ultra Preset.
Doesnt matter if we are, 2 * 3Gb cards will have 3Gb of VRAM available because data is mirrored on both cards (ie duplicated)Think I am getting confused here, Are we talking crosfire?
 It's a shame some of the forum are incapable of 'discussing' things in a grown up manner.
As you can see from these screens. This is 1080P @ full ultra (all the trimmings)
I have the page file on also.
Hows this lol
Ok only 1 of them in over the 3gb mark but the rest are dam close to it.
You're running xfire, so it's a total of both cards which are duplicated data so really you're using half of the reading you get. ~1.5gb.
Have you tried disabling it to see if your VRAM usage increases?
Game crashed for me when i disabled pagefile.
Shame as i did see a good boost in FPS.
