Thought I would create this thread just as a timeline on how my skills, technique and creativity change while I learn new things. I have just really got into this over the last month and think I have become addicted!
This first batch of photos are repeats from separate threads but this will be where I post this from now on.
All photos are pretty must straight out of camera, only PP is possible slight crop, small levels adjust and slight noise reduction depending on conditions.
First Physiogram
First Physiogram by M+M Morrison, on Flickr
Red Physiogram by M+M Morrison, on Flickr
A bit of light-painting
Barvas Ruin by M+M Morrison, on Flickr
Then the Orbs, first came the making of the Orb tool and the first Orbs.
The prep
Can you tell what it's going to be??? by M+M Morrison, on Flickr
The first Orb
First Orb by M+M Morrison, on Flickr
After the first night the wire I used broke, so got the tools out and used a good bit of Hi Flex power cord. Results was quite better and more controlled, a bit more practise and should be looking dam good
Was quite hard avoiding the couch and worktop though hence one or two off swings.
Another Indoor Orb by M+M Morrison, on Flickr
Then the first 'Outdoor' Orb. Came out pretty good although the exposure was too short so had to up the levels slightly.
First Outdoor Orb by M+M Morrison, on Flickr
Then a bit of Aurora Borealis
1*
Aurora And The Orb by M+M Morrison, on Flickr
2*
Aurora Spin by M+M Morrison, on Flickr
First Physiogram
The prep
The first Orb
1*
2*
