What does Ultra mesh do?
Draw distance aka how far away u can see stuff. U wanna keep this on ultra.
Take the helicopter over the mountain.
Will try this as it seems u play BF3 more than u used to play quake3, what does mesh quality do?what ingame settings are u using? i use everything on low except mesh quality! which is on ultra!
Think I had this on lowDraw distance aka how far away u can see stuff. U wanna keep this on ultra.
60-70fps on metro, have maxfps on 45 to keep it stable on caspian high textures atm.those using the injector make sure you turn msaa offthats the whole point of the mod
ive played through single player with injector on and with it off.
Havent used digital vibrance in the nv control panel. But my monitor, (benq fp241w) has various pre set modes that you can select via a menu button. Using the dynamic setting mode sharpens and brightens the colours, but it can look a bit too bright. So i use the fxaa injector, though i may remove it now and just use the latest nv drivers as its included in them.Has anyone played with digital vibrance (nvidia) or saturation (ati) ?
I tried last night on saturation +200 and even tried hue +10 to fix the colours
This is why i stopped using it. Looked horrid to me without 4xaa even with using the fxaa injector. I just couldnt stand the jaggies. Once you've had 4xaa for a long time, theres no going back.
When i used 4xaa + the injector it harmed performance so i had no choice but to remove it which is a shame because i did prefer the crisper image and much better colour saturation.
Might try the injector thing, my system is pretty poor tho60-70fps on metro
True, playing on it just now. It's a terribly thought out map, chopper can be useful. But all too often it's been flown by an idiot who wants to just go and shoot things up.Damavand peak
Such a beautiful scenery but ruined by poor hourglass map design. The tunnel is serious bottleneck in advancing forward to the other side.
msx4 and the injector on theres basically no difference in image or not very much saying its jagged is a bit hmmm wrong tbh. look at the jaggies there so bad
i did hundreds of screenies max settings with no msaa on and it looked stunning
This just made me think of Kubra Dam in BF2, I can't believe the tiny scale of the maps in BF3 in comparison!
Has anyone managed to fly the little bird through the tunnel on Damavand Peak?!
