Where I disagree is that all the numbers being inputted are random or guesses. If they were I would agree that it is essentially useless. Some of the initial numbers were guesses, but here we are 50 years later with billions invested in space technology. One could hardly say that this is just for the random hell of it. It has been to quantify and further our knowledge of "the final frontier" (sorry Cpt Kirk) As new information becomes available due to research the variables become more accurate and the equation takes more solid shape. It's an ongoing process.
Consider the alternative to think of it another way. Should we just give up and stare at the stars blankly because it is "all just too much to comprehend"? Should we not try to apply math to the situation to try and extrapolate outcomes? The logical mind can only reach one conclusion.
Do you believe that the only alternatives are pretending that a description of something after the results are already known is a prediction of the results and "just give up and stare at the stars blankly because it is all just too much to comprehend"?
Or are you just making up a false dichotomy and claiming that the other option is what people who disagree with you have said in order to make them look bad, i.e. simple ad hominem because you have no rational argument?
Either way, you are talking rubbish.
The Drake equation is not maths.
The Drake equation can never, under any circumstances at all, predict the number of advanced civilisations in the universe, or any part of the universe. It can't predict anything.
IT IS A DESCRIPTION FOR AFTER THE NUMBERS ARE KNOWN, NOT A PREDICTION OF WHAT THE NUMBERS WILL BE.
If I post that again in bold in a font so big that every bloody letter fills an entire screen, will you pay any attention to it? Maybe I'm just not shouting loudly enough.
Yes, I am angry. If you can't make a counter-argument to what has been written, at least have the common courtesy to ignore it rather than making stuff up and pretending it's what has been written.
EDIT:
To clarify - all the numbers being fed into the "equation" are guesses. In order to put anything other than guesses into each term in the "equation", you need to know
a lot more than the final answer. Say, for example, our far ancestors complete the aeons-long project of exploring the entire universe. They know exactly how many advanced civilisations exist, with complete accuracy and beyond any doubt. Even then, they still wouldn't be able to assign anything more than estimates to the terms in the "equation".
Just one simple example, using only 2 of the terms:
10% of planets that have the potential to support life did have life at some point in time. 1% of those went on to develop intelligent life.
Or maybe it was 20% of planets with the potential to support life that did have life at some point in time, but on half of the planets life died out so long ago that there is no trace of it. 0.5% of the planets that at some point had life went to develop intelligent life.
The results are exactly the same (0.1 * 0.01 = 0.2 * 0.005). There's no way to tell which is true, or if either is true. Maybe it was some other unknowable combination that produces the same answer. So it would still be guesswork even after the final result is found out by surveying the universe and counting the number of advanced civilistions. At the moment, it's total guesswork, just random numbers slapped together to get any result that anyone likes.
So the numbers will never be anything more than some estimates of largely unknown (and in many case unknowable) numbers that multiply together to get the end result (which you can only get by surveying the universe and counting). Right now, the numbers are total guesses without any substance.
I'll illustrate with a general example that means nothing. So it's just like the Drake equation. I'll throw in a term that can't be clearly defined, to make it even more like the Drake equation:
a * b * c * d * e * f * g = x
You know from experiment that x = 20.
You know that a = 50.
You know that b = 0.8
You know that c has some value between 1.4 and 2.2 (it's impossible to be precise because c is a description of a term that can't be objectively defined).
Now calculate d, e, f and g (since it's impossible to find them by experiment unless you also have a time machine and enough time to study the history of every planet since the beginning of the universe).
It's impossible...and that's true even when you have already found the answer by experiment. That equation can't be used to calculate x. It can't even be used to find accurate values for most of its variables even after you already know x. Just like Drake's equation.
