Can you post up a larger res version of the first pic?
Here you go.
[TW]Fox;21697082 said:I disagree. Provided the gearbox engine were legitimately aquired and currently function correctly there is nothing wrong with them that would allow a refund under SOGA, surely?
Is it possible the bellhousing had a lug cast in to take the dowel, but it's been snapped off by careless handling? The rust on the dowel suggests it's been like that for quite a long time.
Why are garages so ****ing useless these days.![]()
You go in asking for help on specific things and you don't even get a legitimate paper trail to those very issues you have at hand. Just a load of guff about general wear and tear items to make you feel better about fleecing you of £25 quid.
Can you take a photo of where the engine number should have been. (the one that is supposedly visible that is..) How has this been "removed"
Looking from the perspective of the OP as a "no nothing about cars" Firstly I'd want to get a decent set of non buckled rims on the car and the wheels balanced properly.
This you should go through the original purchasing dealer to get rectified.
If the vibration ceases then things are looking up.
If not, then gearbox to engine mating issues have to be thought about.
Because of the worry about the legitimacy of the original purchasing dealer and the cars issues of not being quite what it seemed, I'd be taking the car for a fresh MOT myself to see if any items were actually pulled up on.
Knowing Ford main dealers they are just into a bit of "work generation" by mentioning the wheel bearings and brakes pipes..
I'd want that looked at "officially" by the man who passes and fails things, not some main dealer oik having a quick nose at it.
This you can then use in your armour, along with the engine box issues to reject the car on the grounds of not being in a satisfactory condition or being mis-sold to you.
Get things in writing at an early stage. Scraps of hand scribbled paper are no use to no one if it has to go to court.
).How much did you pay for this car, if it was one these billy bargains, then learn your lesson for the future, if it seems to good to be true..........
Sounds like a useless Ford dealer. Get on google and find out the trans and engine number locations for what the car is "supposed" to be. If you can't find them then get the torch and degreaser out untill you find them.
Without them you've nothing tbh. Not only will they tell you if they are the correct parts, but IF they have been bodged then you will be able to work out what from etc.
Stop being so harsh on yourself! Even the well clued up on here wouldn't have thoroughly inspected underneath a 3k fiesta from a garage - if only because you simply can't. Even with a look underneath I'd wager 99% of experienced people would not have noticed that gearbox issue, and plenty would miss the buckled wheels too. This is why the law protects us and by buying from a trader and therefore being protected by the SOGA you've done the right thing.
You noticed the vibration and were told it would be sorted, but it hasn't been. It's certainly not beyond feasibility that the trader never noticed the gearbox issue, and maybe even the buckled wheels - even after rebalancing the fronts and going on a test spin, if he didn't reach 65 he might have thought all was resolved. OK maybe I'm stretching giving the benefit of the doubt a bit far now, but it doesn't matter as you're protected by law - you've now brought the issues clearly to his attention and can demand they are fixed to your satisfaction or reject the car. He need to get the wheels replaced and see if that removes the vibration once and for all, question the corroded brake lines if you like, then really get to the bottom of this gearbox issue. Only accept it if you're satisfied. If you're not for any reason you should be able to reject it under the SOGA citing the incorrect fitting of the gearbox/it's damage/missing bolt etc etc.
Good luck
You can only learn from mistakes and bad experiences.Who else uses that Ford Diesel engine, iirc some of the ford stuff is shared with the PSA group.
but its a PSA group engine shared with ford, not the othe way round
though to be fair, it was a joint venture but the french just build diesels better than ford
This is true. Even though I'm not an expert, when I bought my car I checked everything I could think of thoroughly, but the only time I got underneath, well not really even underneath more peaking the head in, was to check the sills for corrosion and just had a quick glance to see there wasn't anything visibly wrong with the chassis. Didn't even check the actual wheels! Reading this thread next time I might pay more attention to the under body of the car!
Also next time take your brother along, always good to take someone along who knows a little about the subject.You can only learn from mistakes and bad experiences.
