Self filling washer bottle!
15 Nov 2008
I have an idea! Just wanted to see what other motorist think about it?
Imagine that you never had to fill your washer bottle with water again because the rain water that falls on your bonnet and windscreen was channeled into your washer bottle and and passes through a slowly soluble tablet of screen wash additive that would only need changing once a year ! I think it would be good for few reasons! Safety and environmentally !
filling up your washer bottle isn't hard or expensive though.
Then again a guy from sales managed to pour washer fluid in his brake fluid reservoir once. Lols ensued.
I'm intrigued. Tell me more about the financials.
I know of "professional" drivers who have done many similar things..... :D
I thought of this when I was about 7. My Dad and I implemented it on his Saab that very evening, by putting a little collector in the bottom of the scuttle panel.
The trouble is, you need to filter it well to stop you getting **** in there, which is probably a case of having an initial catch tank that overflows to the main unit as well as a gauze filter somewhere, that's probably always going to get blocked up.
Beyond that, you'd need some kind of vacuum drawn system to add some solution to the water as well.
That's probably why it hasn't been implemented - it doesn't solve that much of a problem compared with just topping it up every so often. Especially seeing as a lot of cars now seem to have washer tanks of 5L or more!
Risk Versus Benefit
Risk:
Poor filtration putting particles/**** in system and destroying pump
Some vandal pouring something nasty in it
Benefit:
Not pouring water into it manually ever 2-3 months (depending on how much you lay on the spray)
Conclusion - Not worth it.
As mentioned also, you still need to dump anti-freeze/cleaning agent into the mix and that will eventually require top-ups.
The time I think it would be most usefull is in winter when you are constantly washing the salt off the screen ! That's when its most dangerous to run out and visibility becomes an issue!
I also think the manufacturers would jump at it seeing as its another clever green bow to there string seeing as everyone is so green ! Lol
No one will jump at it, as we've already stated, it's so complicated to do properly, it's easier just to fill up as normal.
I'd rather know that I'm pouring in clean water than have to worry about water filters or tablets or anything like that.
What next, windscreen washers with Brita Maxtra technology? :p
I actually designed my system 15years ago as an apprentice project whilst working for BMW UK B-)
If there's a hole to let water in, it will evaporate out through this hole too. Plus, it's dirty rain water
Rain water is actually quite clean - in fact usually cleaner than tap water once you've done some overflow filtering.
Thanks for all the negative responses guys! You have obviously never run out of screen wash on the motorway in the middle of winter and had difficulty seeing where you were going!
Oh and there are millions of intentions in the world we could do without but we all seem to buy them! Or am I wrong?
You're missing the point though, the easiest way not to run out is to simply fill it up before it runs out.
You'll have to add some screenwash solution anyway.
Add that to the additional complexity of the system and it just isn't worth it.
