Still waiting on the MSI coming in myself, hopefully there will be a decent amount coming in or they will sell out in no time!
I asked about the stock coming back in earlier today and at the moment there isn't a confirmed date. Hopefully soon
Ok boys and girls, my Gelid cooler turned up today, so that got slapped on and a bit of testing got done. Now I'll say from the off that my 7850 ain't a good clocker, I was lucky if I could bench heaven at 1150 core with 1190volts, and crysis 2 kept crashing at anything over 1125 core, with the same volts, temps in both heaven and crysis would max out at about 72c-75c and thats with the fan at around 60%-70%
Now with the Gelid cooler, I can run crysis 2 at 1160 core, 1180 volts and temps NEVER go over 42c! Heaven can bench at 1185 core at 1.2 volts, and still the temp never goes above 40c
When I tested Heaven at stock, I saw 37c load.
I haven't sorted out the fan speed atm so its running at 100% with no speed control available, but more of that later. Heres some pics:
By rainstel109 at 2012-04-18
They do like their thermal paste, whoever put this much on must be costing VTX a fortune!
Same goes for the heatsink base, they absolutely smothered it on.
Heres the actual cooler mounted, all the ram chips and VR modules have heatsinks applied to them using the thermal tape which, btw, was doddle to use and very effective. I couldn't use tall sinks on the vrms as they fouled the bottom of the cooler when it was mounted.
Heres the card installed in an Antec 300 case. when the cooler is mounted, it makes the whole vid card assembly about 3" longer but luckily the card is short anyway. Longer vidcards I reckon might pose a prob if used in a case like this and the gelid is used.
Now about the fan. Both fans run at max speed all the time, about 2200rpm, and thats plugged into the vidcard via a 4 pin plug, but only 3 connections are used so this means that PWM control of the fan speed is not possible. Although the fan is deffo audible, its not too intrusive and more of a "low "wooshing" noise than the whine you get from the VTX cooler fan.
But, in the box that the cooler came in, theres fan connection lead that has an identical plug on one end, but with 4 connections used, a molex connector in parallel and a female fan socket mounted one of the other ends. This, I believe could be a conversion cable for the fan to give the user auto speed control, though saying that, it could enable use form a baybus fan control panel. but if thats the case, why have all 4 connections occupied?
I'll be looking into this in the next couple days
So, is it worth it? For me I'd say yes, its enabled me to drop me voltage a tad, raise the core speed a tad too, and keep the temps down to a ridiculously low value. This is for gaming, not benching as in Heaven I can go a bit higher still before crashing.
Any questions, feel post here and I'll do me best to answer them.
I'm going up to 95c in UNI with 1.175v @ 1200mhz core/5600mhz ram - Why are my temps so damn high :S. My idle temps are 58/60. I have two cards in crossfire but surely that doesnt explain such high temps :S.
I couldn't afford one of these so machined the stock amd 8150 cooler, similar results though
http://bugsy.pwp.blueyonder.co.uk/ati78503.jpg
Nice job done there mate![]()
I'd like to thank the people who made and contribted to this thread.
I now have my VTX 7850 running quite happily at 1200 / 6000 @ 1.58V
tested and stable under 100% load for a few hours![]()
72C is perfectly fine, good OCCould prolly drop the fan speed down to 50% and still be under 80C.
