- 10 Aug 2010
- Somerset
By the way, what about the power, is 430kW going to be enough?
Are these £7 worth spending on the difference like Cosair and XFX have? Or Cosair will be enough and XFX is just for the sake of convenience of connecting it? Because I have a lot of 6 to 4 pin adapters connected at this moment. As you mentioned Cosair has its downsides when compared to XFX, but I bet XFX has some downsides as well when it is compared to something better.+1
It's a nice unit, doesn't cost much and it will power all your kit.
However, there are a couple of downsides to it which aren't deal breakers but worth considering:
- it only has one PCIE 6pin power connector - the ASUS/OCUK HD 6850 OC technically needs two of these connectors, though you can use an adapter (that should come with the card) to convert two 4pin molex connectors into a 6pin PCIE power connector (like this one)
- it only comes with a 2 year warranty
Therefore, if you are willing to spend an extra then you may want to go for the XFX 450W.
This supply comes with two PCIE power connections and a 5 year warranty. Here is an in depth review.
To be clear - the Corsair 430W is still a great PSU, will meet your needs and is a bit cheaper. But if you can stretch to the XFX it may make life slightly easier.
Do you know the model number/name of it?
Coolermaster have made a few different 430W PSUs, some are very good, some aren't.
Most likely it will be fine, but if it is one of the low end ~70% efficiency models with not-great regulation then I would suggest an upgrade (to the cosair 430W or XFX 450W),
No, no, I was still talking about cosair, was just concerned about small power upgrade from my old PSU, but you have already destroyed them by saying that cosair and xfx are efficient.
About the CPU cooler. I was measuring dimentions inside my case to check if it is going to fit or not and realised that I dont know which way round to put it in order to have the most efficient cooling. Is it better to put it so that the fan would be on either side of the sink, on top or on the bottom? On the bottom would be the best in order to get rid of hot air from the sink (since hot air goes up and fan will speed it up), but it will not cool the air so much and the hot air will go straight to PSU. If it is on the top it is best to cool down the air, since air will be trapped longer in the sink and will be affected by the fan longer, but there is a thred of hot air build-up. So I would suggest on either side of the sink would be the most efficient one, are my assumptions correct?
Generally cases are set up to draw air in the front, and exhaust it out the back. Assuming any current fans in your case are set up like that, then having the cooler blow air over the heat sink 'sideways' is best [i.e. from front to back], then all the fans are working together![]()
+1
While you are checking your case, may I ask what the size of the fan is on the rear exhaust? Generally they are either 80mm or 120mm (sometimes 92mm)?
Also, do you know the make/model name of your case? If it was a pre-build, do you know the make/model of the PC itself?
Seems like a brilliant option for the case upgrade.That said, it seems to be a rather old case which doesn't cool very well - so you may want to consider upgrading to a cheap but decent case - like this one. This case has generally much better cooling (120mm case fans, PSU on the bottom) and will allow you to use a larger CPU cooler (like the Gelid tranquillo).
Here are some reviews for the £32 Bitfenix alpha case:
http://www.kitguru.net/components/cases/simon-telford/bitfenix-merc-alpha-chassis-review/7/
http://www.anandtech.com/show/4913/bitfenix-merc-alpha-how-much-can-39-can/7
http://www.overclock3d.net/reviews/cases_cooling/bitfenix_merc_alpha_review/1
