- 16 Jan 2003
- Nottingham
Yep fine Broken Hope, I will re-install, it doesn't "seem" to take too long
Re the firmwareshouldn't that already be up to date? The drive is only 3 days old, well to me
& is it difficult to do?
There's been 2 newer firmware updates since 0009, it's really simple to do, you simply double click an exe file and it reboots your system, flashes the firmware then boots back into Windows, you don't have to actually do anything yourself.
Here's the file from Crucial.
http://edge.crucial.com/firmware/m4/000F/m4_SSD_Firmware_Update_Utility_000F.zip
