new z77x ud5 + 3770k wont boot
oh :( are people serious that you can't get into the bios on the UD5 and the G15 keyboard?
one of the most popular USB gaming keyboards ? just I have a G15 and was going to order a UD5 tonight ...
iv not had a problem with that keyboard with any other mobo iv had and delete does try to get it into the bios. i dont think the keyboard is my problem
Depends on the BIOS thats on it, but the F6L was released to fix the G510 keyboard issue and happened to work with mine.
Do you have a crummy one lying about just in case?
nope :( well I have 2 wireless HTPC keyboards
only reason I'm nervous is my HTPC - Gigabyte 9400 based mATX board is a NIGHTMARE to get into the bios - its practically impossible with wireless keyboards (1 in 10 attempts if that) - and with the G15 via USB perhaps 50% success rate
don't have any issues with my older P5B Deluxe Asus - so I don't see the issue
its almost like the Gigabyte mobo is initialising the USB/keyboard too late
Well I have the same motherboard and when I went to install a 3570k in it, and set it all up, it wont boot :mad: Same motherboard and sounds like the same problem. It boots to a blank blue screen. Also the debug LED comes up with the code A6. Which according to the manual means 'Detect and install all currently connected SCSI devices'.
Had this board for the last 3 weeks and when I finally get my new cpu, the bloody thing wont start!!
Power OFF, clearCMOS?
When does the Blue screen show up?
Can you see the BIOS splash screen to enter it?
Cleared the CMOS, did the one stick of ram nearest to the cpu trick and a host of other things. I think its probably a duff board. Funny that me and someone else have the exact same problem. The blue screen itself shows straight after boot. The bios wont boot at all.
I have wasted hours tonight. Not happy with Gigabyte and this duff board. Sorry to whine so much, but I have been waiting weeks for ivybridge to come out, and this board has been staring at me for weeks. And when I finally get the cpu to install, this happens :(
If you have GFX cards installed, pull them out and use the onboard solution.
Any drives you can disconnect as you dont need them top get into the BIOS.
Yeah mine isn't a blue screen of death either, but just a blank blue screen relating to the motherboard. It wont even load a bios message let alone boot to windows :(
I got into the bios just fine with my G15 with the f5 bios (which it shipped with)
back to the topic in hand
the thing is i know what the poster is saying about it hanging when you enter the bios it happens to me but only after i havent put enough v-core and the overclock fails
offshot, when installing with 1 stick of ram, have you tryed manually putting ram setting's in then see if it still bsod's?
