- 27 Oct 2006
- London
Sending mine back and ordered 2700K
Please update your signature.... let me also show you the way to the door
Heres a quick run at 48x, 1.4v. Any lower than 1.4v and it wasn't stable.
One of the cores was hitting 92c after only 2 minutes, and that was with my H100 set to maximum.
Because i was able to hit 4.9-5Ghz with the 2600K (which i've now sold!), and stupidly thought that IB would overclock more due to the smaller fabrication process.
My own fault for not reading into it more before ordering!
Ollie1132 posted picture in some other thread.
4750 = 5ghz ivy.....
its close tho
Ive seen quite a lot of 4.8Ghz on 3570k's most people are getting mid 70 to low 80 temp wise. Think I even saw a 4.9Ghz earlier.
4.8Ghz on IB needs a lot of volts.
mid 70's 80's temps are not realistic unless the load is small.
Anything like Prime or worse still IBT would push temps well over 100
4.6Ghz is as far as you can realisticly push them if you want 24/7 stability and reasonable temps.
Anything above that is just for benching and is not viable for everyday use.
They will reach 4.6Ghz easy enough at 1.3v - 1.35v which is the max sensible vcore IMHO.
Speed: 4.221
Voltage: 1.182 (stock)
BLCK: 100.5
Multiplier: 42
Corsair H100 (medium)
Prime95 max temps: 62-59-61-64
Ollie
How many volts does your IB chip need for 4.8Ghz stable running then ?
We would all value your expert input
