- 7 Mar 2012
Thanks for your replys
So that new psu I have ordered will that do the job for my system ?
was perfect untill i loaded battlefield 3 played for 10 minutes and big sparked and turned off.
if your £25 psu says it's a 700W PSU on the sticker it'l only deliver near that for about afew minutes before blowing .
it'll be fine if u don't start overclocking the cpu too high like 4.6+Thanks for your replys
it's rig would be using 450-500w~ hence why it lasted 10 minute. anything over that like 600w it would have only lasted afew minutesabout 10 minutes by the sounds of it![]()
Would the psu also be the reason why my CPU was getting temps of 65+ of just only 10 mins of play
are running on stock cooler?Would the psu also be the reason why my CPU was getting temps of 65+ of just only 10 mins of play
well amd BD chips are power hungry even more so when oc'edAre AMD systems the new Pentium 4 EE CPU? I think even 450w is way too high. More likely the system was using 200-300W (300 is still high for just running BF3).
http://www.overclockers.co.uk/showproduct.php?prodid=HS-093-TR&groupid=701&catid=57&subcat=1395 or http://www.overclockers.co.uk/showproduct.php?prodid=HS-010-NC&groupid=701&catid=57&subcat=1395I first put the artic cooler rev 7 on it then see it was running high changed it to the stock cooler Any one recommend a good cooler for this chip only gonna plan on overclocking it to 4ghz
What power supply though? Cheap power supplies will fail
