Liking the pcie power for it. My d2x looks rubbish because of the floppy power connector. Really difficult to keep cables looking nice with a molex to floppy adapter hanging off the sound card![]()
Don't like the look of the control box at all. Looks like a toy.
was looking at reviews of the d2x and looks like there are a bunch of leds with the thing and a floppy power cable ... is there anything that just doesnt look gimmicky? ...
might be tempted with this thing - just want to hear some reviews first thou. The stx or essence cant take 5.1 analog can it?
This is ridiculous... I doubt you will ever get any audio which can even utilise the full power of this card, as most of it is such low quality anyway.. only useful for true audiophiles and rich people![]()
Never felt the need of a sound card, onboard with a decent set of phones and a Fiio amp has never let me down. Especially at that price. :O I thought gpus were getting bad.
I have sennheisers hd 25-1 ii's so they're quality cans, as for the amp um think it's an e5 , which the headphones go in then from the amp to the headphone port in the onboard. my crosshair iii had a dedicated sound card and it didn't make any noticeable difference. Either way it sounds decent the way it is, I just personally wouldn't spend this on a card but I can see why people would. Just as literally when I'm home from work my cans and amp just go into my pc.Fiio amp connected how? If it was a USB/Optically connected DAC you were never using your onboard sound in the first place. I also cannot begin to believe you would use a decent amp connected to on-board sound via analogue with decent headphones and think it was utilising them as much as decent source equipment could.
If you have never used dedicated a decent sound card how would you ever know the difference to onboard?
The difference is very clear with proper mid-range to high end speakers/headphones.
If you are running some cheap £5-40 set of cans then no, you wont notice the difference.
Most (all) games use high sample rate audio.
