Very nice! You got a KFA2 that goes over 1350 Mhz
... (Wanna swap?).
WHAT!!, when will they arrive?
Should arrive on Wednesday!
No thanks
But I think I sell or DSR mine and go for Asus DC2, as fans at low speed annoying me, I hear something like high frequency noise.
Two should be a good test for fan noise on these cards, if the DirectCU II can run quietly in sli then these are the cards to have.
You're going to DSR a 1350+ Mhz chip? Are you mad lol.
Sell it instead.
Just rang OcUK and they seem pretty sure they are getting the DirectCU II in tomorrow, chap said around 30-40 units, maybe Gibbo can confirm?, I think I'll be grabbing myself one anyway.
The thing is there is no telling how many of those units will be taken up by pre-orders, non I hope![]()
Maybe you right, I will sell it then.
I would think they will have stock for you, if you think about it the Windforce is the more desirable card, £5 cheaper, UK RMA base, decent clocker, full 680 PCB etc... and they still have heaps of windforce stock![]()
Asus has the lowest temps here, but the gigabyte wasnt tested:
The gigabyte cooler also uses direct contact heatpipes:
Honestly, the Gigabyte cooler looks far better, and its proven and tested by enough people running their Gigabyte GTX 670s overclocked with temperatures under 60 degrees.
Where are those results from, they look a little high, even my reference card never hit 82c on load, and the idles look too high, mine is idling right now @ 29c.
