Hi there
On the road the 911 handles great and has mild understeer. On track however the understeer is more pronounced, I've messed with pressures but that's just moving grip around, not improving anything. Yep there is trail braking of course which helps but I'd rather improve the car too.
Spoke to a few people and many recommend widening the front track not only helps with understeer but settles the front end down more too as it's lowering centre of mavity too. So some recommend that just adding 5mm front spacers helps a bit. Or adding spacers all round improves the whole cars ability marginally or even better fit them all round but say 7mm on front and 5mm on rear to get overall improvements while dialling out some of the understeer.
Thoughts?
Of course what works best to get rid of understeer and improve car further is GT3 sway bars front and rear which are adjustable so can set the car up and even better GT3 lower control arms as the stock Carrera suspension can only max upto -1 degree camber whereas GT3 arms give upto -3 degrees negative front camber which greats helps dialling out understeer. However these mods could be warranty issues whereas spacers are not as they were a factory option.
Thoughts?
