It won't even paste right into the forums so I'll just leave it before my PC takes a trip out of the window.
Cheers anyway guys
Ok it says this under foreign address for the first Diablo III on the list.
78.141.177.154:https ------------ CLOSE_WAIT
then the other one is
80-239-209-146:1119 ----------- ESTABLISHED
Many thanks for the help
having one of the worse experiences so far - installed D3 on Tuesday ready to go and couldn't login due to authenticator code being wrong - then dawned on me i deleted the Authenticator app from my phone ages ago - which i didn't know but this apparently locked you out from your account - so i try to phone support which is by far the worst support number i've had the misfortune to have to ring - 3 days later and multiple 40 mins in the queue later i get told they can't help and i need to fill in a form on the website...
Already very angry i fill in the form attaching my birth certificate as the unhelpful support guy tells me this would proof enough - it's a battle.net account, not the keys to fort knox for god's sake!
I then get an email back before says they couldn't process my request as the proof wasn't good enough and to login to discuss it more - i can't login! the whole situation is because i CAN'T login - oh god the shame of it is unbelievable - support has hit new lows...
Are there any fellow wizard strugglers? Act 1 & 2 (normal mode) didn't seem too hard. Apart from the final boss of Act 2, which took me around 8 attempts. I figured this was just intentionally hard. However a friend of mine whose a Witch Doctor, took him down on his first try and is steam rolling through Act 3, whereas I'm dying/chugging pots fairly regularly.
Any wizards got any ideas? It may well be the build I'm using, it's very much kamikaze, I run into packs of mobs using diamond skin and then let off a boat load of short range aoe. Rinse and repeat. I'll post up my full build when I get home from work, but if anyone has any ideas I would be most grateful.
What happens if you type tracert without the numbers after it?
Sorry, Chokka... This is driving me insane.
"The best and epic hack 'n' slay..."
That doesn't make sense???
Tracing route to 80-239-209-146.customer.teliacarrier.com [80.239.209.146]
over a maximum of 30 hops:
Edit : Is there a post with everyones battlenet usernames?
