- 18 Sep 2009
- Dormanstown.
*An unlocked BIOS for an Asus 7970 DCII specifically*
Aka, someone else with the card or Asus themselves?
That isn't going to make the programs magically update their VRM library.
but afaik, 7970 specification, whether ref or AIB specific has the potential to go to 1.3vcore.Well, TriXX does something different to my card. When left to its own the card reduces gpu voltage in idle mode when it clocks down. However when I set gpu voltage with TriXX, the voltage always remains at its maximum set value.
I could, but it's not worth it.
If I was to return it, it'd only be to go back to my 680.
Only way I can have my tridef 3D.
was a downgrade to my GTX680.
You'd have to be touched in the head to buy that.
Are you going to give me the 70 for a waterblock?
Thought you was loaded, buying all those different gpu's so often?![]()
Is this members the same card as yours?
http://forums.overclockers.co.uk/showpost.php?p=21931543&postcount=10
