- 11 Dec 2002
- Darkest Norfolk
hrm, that does look very odd - first port of call would be to clean it. Theres a philips screw in the middle of the shower screen (mesh) that unscrews, drop that off and give it a good scrub.
Next remove the two allen key bolts in block there and take the big chunk of metal out, it may need a little bit of levering. Clean and replace
If that doesn't fix it there may be an issue with the pressure (looks like it could be really high) there are guides earlier in the thread about adjusting the water pressure but you'll need to get a backflush plate to work out what sort of flow your getting through (you might as well pick up some cleaning stuff as well - http://www.happydonkey.co.uk/gaggiaspareparts.html for example)
. I will try to dig out the caffatiere for tonight, as we have friends over who normally drink there coffee made that way, so it would be good to get there input.
