HELP - Problem with PC :(
12 May 2012
Hi
some of you may know iv just built my first pc, all was fine untill 10 minutes ago
I have the GTX 670 graphics card and was experiencing the drivers failing, so i did a bit of research and found a thread stating a fix. this was to unistall the drivers and revert back to an older driver.
As i started to uninstal my drivers for the card, suddernly i lost my screen (i thought was normal)
nothing happened for ages so i restarted and still have no screen or lights on mouse/gamepad etc.
Iv tried different cables plugged in to the mobo and card, tested the screen on another computer, the fans are on and the pc seems to be on but the screen, mouse or anything doesnt seem to to be working.
any clues as to what to do?
thanks
Remove the card, use on-board or a older one. Start in safe mode remove the old drivers, installed the new ones put the card in and try start normally.
ok, not massivly technical here, how do i start in safe mode?
Push F8 on the launch usually.
Or turn it off during the windows loading screen and restart it should come up windows didn't restart properly blah blah choose a mode.
do i instal the new driver before plugging the card back in?
then switch off, plug card in, reconnect hdmi to card and start normally yes?
Assuming you've downloaded it already you can just install it when you're on safe mode. If not just remove the old drivers then place it back in and if it starts install the driver you want.
further investigation, if i take the card out i can get everything to turn back on? what does this mean?
That your driver is wrong or the card is goosed.
ok i did all that
the problem is now it wont let me instal the drivers becasue it cant detect the hardware (not plugged in) and when i plug it in (the card) the dispaly doesnt come on at all...
stuck now haha
(just what i need wen im going away tomorrow :(
ok i did all that
stuck now haha
go to the manufacturer website and down just the driver manually :0
ok i did all that
stuck now haha
How are you connecting your monitor to your card?
Try using the custom install rather then the express install and only install the driver also use a VGA cable instead of a HDMI.
it doesnt even get to the point where i can choose, it unpacks and then starts automatically, but says cant detect hardware then automatically stops.
ok ran the disc
choose the set-up icon and same thing, it starts then says it cannot find the graphics card.
is there a way to manually install the drivers? theres so many files i wudnt know where to start
ok ran the disc
can you open contents of fold on the disk and manualy select the driver and install it
i have uninstalled them all yes
if i plug the card in, the display will not turn on at all no matter where the cable is plugged.
is there a way to plug the card in and get the computer to boot ignoring the card?
