*** The Official Diablo III Thread ***
Status
Not open for further replies.
yeah i know that, but how exactly are you selling so many items and making a huge return? there are literally hundreds if not thousands of the same items going for x - y prices i put up a +56 vit/58int necklace lv 18 for under 1000 gold, and not one taker it's far less than what others are putting up 50k+ :confused:
level 18 gear wont sell so well because at that level gear don't really matter, as it will be replaced pretty quickly.
Not played a demon hunter so no idea about weapon preferences etc.
On a cross bow/bow you would be looking for high DPS, dex, crit dmg, +dmg, hatred regen, vitality and sockets (they are not in any order).
If it doesn't have any of them on it then just sell or DE it, that's what I do anyway.
Agreed, but at 1000 it's better than what most will get in drops and far better than merchants at a similar cost, where as most others are on there at 50x my price and seem to sell with the same stats?!!
it's just madness...think i'll only use it once i'm capped so i don't actually feel robbed of the prices everything is at atm, especially when it will only last you a few levels :p
looking forward to set items mainly...
I'm really struggling with Belial on NM at the moment, had little luck trying to as someone here earlier to help me but gonna try again. Perleeeeease!?
powlesY#2690
Thanks in advance for anyone wonderful enough.
I cant see a lvl 18 item selling for a lot, maybe 2k at most? Depending on stats ofc. I got 2 lvl 26 legendary belts i cant shift. :(
The economy on the AH is still teething, i think it will take awhile to normalize.
wow champion/Elite frog owning me so bad in hell Act I, kills me almost instantly. Grimock the Gorgon with frozen molten and invulnerable minions. GG
yeah we can hope, it's just gunna get worse when real money trade comes into it...
Guessing the root of any shrvivability issues in nightmare as a 47 monk is that I have 927 dex, and only 192 vit! Oops, ATM it's a massive dps race, fine on normal mobs and bosses but I get destroyed by the other stuff, lots of hitting and running. Got 1.8k damage.
1.8k damage in NM should be fine ive only got 2.3k and in act 2 hell although Im struggling a bit now need a better wepaon this 153dps axe isnt cutting it any more :D
I only had 1k dps on my monk at 50 after finishing Act 3 nightmare :D. I think I had about 1.2k when I started Hell, basically whatever leveling up a couple of times would give, since I can't remember getting any decent dropd after that :(.
Luckily I got 259DPS 1h drop near the start of hell, so once I equipped that (and got rid of my off hand weapon, since using one instead of a statless shield dropped my dps by about 500) it went up to about 2.2k or something iirc.
My lvl 48 monk is putting out about 2k dps and while im not sure of the Vit stat my hp is just over 21k. I still get battered by some elites though. Found that after act 1 Nightmare I really needed to up the vit and armour a bit. I have only really played co-op with a barb friend who is very well geared and just seems to stomp all over the place looking like a super saijan most of the time.
/Salsa
Well, Act 1 Inferno is a bit of a let down. Was hoping for a challenge, but it's easier than the other difficulties! Apparently Act 2 is a step up, but I just can't see it being challenging at all. Hopefully I'll be proved wrong and I'll need another 22k dps. :P
Shamelessly taken from reddit. Not bad
Status
