*** The Official Diablo III Thread ***
Status
Not open for further replies.
Anyone else getting 'Auction Failed' when trying to list items?
Was getting the same problem last night to...
EDIT: Weird, only seems to fail with some items. :s
I don't know if AH is working properly. It doesn't seem to refresh for me ever, items that are bought by someone will stay on the page all the time :S
The AH really seems so full of bugs at the moment. I hope they iron all this out before RMAH comes out. That'll be a disaster otherwise.
Can someone explain weapon stats to me. I have a lvl 30 wizard and he had an offhand with something like +45 int but when I equipped another offhand with just +4-6 damage my dps went up by a huge amount!
Its because int is a % increase of your weapons damage.
At low levels +4-6 damage is a bigger increase then 45 int gives.
At higher levels (with 400+ DPS weapons) 45 int is much better then +4-6 damage.
So I just finished the game on Normal, took around 30 hours. Really impressed I have to say, my first ever Diablo experience and I was completely blown away. I had read up on a lot of the lore before purchasing the game but I think in interacting with a lot of people in the game you find out a lot about the history that way too. Imperius might actually be one of my favourite characters in video game history =) Now, onto Nightmare!
Is there a good Wiki type guide online to help me.
Want to read up on the runes and other bits and pieces. When you level up you can choose a new skill/rune etc etc, is it like D2 where once you have chosen a path you can't undo, I know in that it was sometimes beneficial to save your upgrade skills until you reached a certain level.
Is there any trails/free weekend type stuff going on at the moment so I can try before I buy!?
There are guest passes that you can try and get a hold of, it gives you free gameplay up to level 13 and up to the skeleton king (the same as beta).
http://eu.battle.net/d3/en/game/ all in the official guide.
Unlike D2 you can switch around your skills as much as you want, you're not stuck.
When you go up a level it unlocks newer runes/skills, however a lot of the time you don't actually need to select them. Everything can be changed throughout the game, unlike the early versions of D2 (with the 1.12 patch onwards you could re-assign skill points) so your build can change dramatically depending on what you're fighting.
One thing I will say, and is mentioned every so often, is make sure you have 'Elective Mode' enabled in the options menu as that then allows you to choose any skill in any of the available slots.
Someone just showed me a funny exploit that's going on right now to farm inferno:
boneweave hauberk blocks monsters, making farming on inferno easy if you have decent ranged abilities. And just to note, my character is only on act 2 hell, I'm not dong any of this myself.
How are people getting on with the SS nurf? I find it still does what I was using it for except I can no longer drop agro.
I can drop agro fine but it seems like even with the rune that increases the duration I still only get 2 seconds invis.
Yeah I think the reason they keep putting back RMAH release date is they want to make sure the standard one works before they release it...
Yeah I farmed Hell yesterday with 190%GF/220%MF. Made about 2 million.
Which Acts out of interest?
That'll be nerfed quickly.
kd
Status
