Good point, a sharpened credit card edge may do it, worth a test on some silicon first I suppose.
I'm sure that the average credit card is stressed enough buying the CPU... even if the UK inflation figures are falling
I am also interested to see how this pans out. If it is really that easy to do [just making sure to be extra careful and take loads of time] then I would not see any negatives but the obvious self risk.
Looking forward to a very detailed guide on how to do this should intel not say or do anything
Looking at the decapped cpu there it would seem that theres no smd capacitors etc.. so it might even be more easily done than an old Athlon etc as theres little danger of knocking something off the pcb.
Has intel made any comments on this problem yet?...ive not been following.
I just cant get over how Intel failed to see this issue.
Just a case of avoid scratching the PCB and you're fine really isn't it?
I just did mine, its really simple and took less than a hour.
http://i49.tinypic.com/27yd4ky.jpg[/IMG
Liquid Pro applied:
[IMG]http://i50.tinypic.com/eijw2b.jpg[/IMG
4.4Ghz, 1.160V, MX4, Titan fenrir cooler.
[IMG]http://i49.tinypic.com/ic47xg.jpg[/IMG[/QUOTE]
That is an incredible drop. Well done sir!
It's not really an issue for them though is it?
They cut costs by putting cheap TIM in = profit.
It has no noticeable detrimental affect at stock clocks meaning most people won't even notice.
People can't overclock as much as they should meaning they'll have to buy a new processor sooner when IB becomes obsolete = profit. Also if Haswell doesn't provide the performance boost they need they can always replace the sodler and they'll be hailed as great clockers.
AMD don't provide a viable alternative so they're not going to lose any business by doing this.
Maybe its a bit too cynical, but perhaps they did it deliberately to hamper its overclocking and make the next series seem more appealing.
"The new IvyBridge K series processors also feature immense overclocking as well."
that was taken from the i7 3770k product description so ofc ppl will think it overclocks just as good as the SB's if not better so looks like false advertisement to me
let's all sue them together! get at least a few 100 sigs from these forums alone xD
or lets all just use less money/risk and start 'opening' our CPU's, applying good quality TIM/whatever you want, and DIY it? ^_^
It even seems like they made it 'easy' to open the CPU up, true enthusiasts would surely give it a go, but a tried and tested method needs to be sorted (less risk more success - no blade perhaps? sharpened CC edge as someone suggested? Metal Spatula?
We need more results, as soon as we have true confidence that this will work and is quite simple (1. Remove HIS, 2. Remove TIM, 3. Replace new TIM) then the better we will all be for it lol.
As someone said wont intels plan thing cover this kind of experimentation anyway? for $25?
If intels plan covered it I'm all the more keen![]()
ay, as every day passes the temptation to slice and dice my processor grows ever stronger xD waiting for my liquid pro to be delivered then i think i'm going to give it a butchersprobably going to chop up and old credit card and sharpen one edge of it.
yea will have to look into this
I can't see it saving them a massive amount of money, there must be another reason for the change.
