- 15 Feb 2009
- Bristol
Nice looking case! Quite big for an ITX case though. I guess it has to be to be able to fit such high-end components in it!
Would it be able to fit a 120mm all in one water cooling loop?
So much want! Never liked small cases so much but this makes me want rid of my CM 690 II
Do it! Do it!
Ace isn't that the z77 asus itx board not a h77?
Ace you could tell us the measurement from the bottom of the ITX board to the side panel? or if you can put a M-ATX board in and get the panel on? if its as big as I think it is I'll pre-order
Nath, you could have used a stealth drive cover
kd
