***** BitFenix Prodigy Cases - Ideal for LAN events! *******
I think it was more to accommodate long graphics cards and water cooling tute ;)
And so will the SG07/08 at less than half the volume! ;)
There are tons of microATX cases that are smaller than this, take watercooling and not one, but two full length graphics cards, and are more overclockable!
This seems utterly counter-intuitive to what SFF is meant to be.
At the end of the day cases are very subjective.
It is not like a GPU where you can clearly say a GTX 560 is not as good as a GTX 680. Cases are a very personal thing and different people like/dislike different styles/choices. This is why OcUK have the biggest and best range of cases in the UK. Gives our customers the choice of what they want (or don't want)
Think I have just found my next case. Just need to find out if my Palit Jetstream Gtx670 will fit. I don't mean length wise I mean depth wise next to the side panel as the custm cooler is quite chunky.
Can anyone tell me how much clearance there would be between the pcie slot and the side wall?
Can anyone say whether a H70 with 2 fans will fit on the back exhaust? Just because the H70 has a bit at the top and bottom for the pumps so is bigger than a 120mm fan.
H70 definitely fits.
From the end of the motherboard, to the side panel, It's about 3.7cm
Ohh that's brilliant didn't think to mount it that way.
But just to confirm a 3-slot GPU cooler will NOT fit right? As my GTX 480 has a aftermarket cooler and there's no way I'm going back to the stock cooler for it so I may have to replace cards.
Unfortunately not no. Unless you cut a hole in the side panel lol.
Upgrade time I reckon, we do have some excellent deals on GTX 670s and they fit just fine....
:D
More I read & see the case the more I want to get one :D
A quiet 200/230mm fan on the front, H50-1 into the roof of the case with a 140mm exhaust at the rear.
Gigabyte Windforce 670 on the side.
My only problem is that I have 2 SSD's which will fit into the side panel, but my 3 x mechanical HDD's won't fit as I'd have to remove the top HDD cage to fit the 670.
Also I presume a Corsair HX850 will fit fine too?
After watching ttl's review of this, I want one just because of how awesome it is, need to just decide on whether to use it as a htpc or my main rig, and I'm kinda swaying towards it being my main rig with a 240 in the roof and a 200 in the front (rads) on my CPU and gpu :) maybe even get two because they're so cheap! :p
Anyone?
