I've just had a swift look at the logistics pipes and they look excellent, I'll probably give them a go later. Cheers for that.
not a problem mate
have a look at direwolf20's tutorials on lgistics pipes. that, combines with a bit of messing around taught me everything i know about them. they are so useful for automating things
in my survival non cheating world i have a massive logistics pipe network that can take the output from my quarry, get all the ores macerated/burnt/compressed/whatever, then sorted into whichever of the ~20 alchemical chests i have for items. i also have ~40 automatic crafting tables for variaous things. i also have a request pipe that will make anything that is possible from my supplies or automatic crafting tables and pipe it right back to me
the stuff at the back is just a power supply i hurriedly put together (HV solar array, MFSU and some transformers so i dont blow up the machines)
i've just had a quick go in creative mode and i've just made my first (industrial) diamond using the logistics pipes. its so much more compact than the pipes + engines method. the only worry i have is the logistics pipes trying to overfill my compressors.
*edit*
here's the diamond maker
to get an industrial diamond you use the request pipe on the far right above the alchemical chest to request however many diamonds you want. it will then pump the diamonds into the chest beneath it when its done
the crafting pipes above the machines and automatic crafting tables basically replace the role of the chests, engines and wooden pipes, requesting all the supplies they need from the left hand alchemical chest, popping them in the machines then taking them out of the machines and back into the pipe network to go wherever they have to go next
*edit 2*
Cheers! No I haven't, I'll research them and let you know how it goes. I've got a hold load of stuff set up on my technic world so if you want to see anything else let me know.
i'd be very interested in seeing anything you've made with thaumcraft, because i've barely looked at that mod
