Build advice to a budget.
You can save money by just using the reference cooler with the CPU which will do you fine - unless you intend to overclock? Also I would go with this Corsair case for similar money, much better build and has USB 3.0 ports. :)
YOUR BASKET
1 x MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards £179.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £173.99
1 x Gigabyte Z77M-D3H Intel Z77 (Socket 1155) DDR3 Micro ATX Motherboard £86.99
1 x Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply £65.99
1 x Corsair Carbide 300R Mid Tower Case - Black £53.99
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £41.99
Total : £602.93 (includes shipping : FREE).
I don't really intend to oc, not at the moment anyway..
That case looks nice I'm a bit torn really, as the zalman has more fans, how easy is it to add more, and can you link me to a compatible one.
I have looked at the reviews for the corsair psu, a lot of people have talked about slightly shorter cables, I hope this won't be a problem with either of these cases?
You don't need loads of fans for good airflow and decent temps. The Corsair 300R comes standard with 1x 140mm intake and 1x 120mm exhaust fan.
As for reviews, well..
http://www.guru3d.com/article/corsair-carbide-300r-review/
http://www.techpowerup.com/reviews/Corsair/Carbide_300R/
http://www.overclockersclub.com/reviews/corsair_300r/
http://www.vortez.net/articles_pages/corsair_300r_review,1.html
http://www.hardwarecanucks.com/foru...s/53047-corsair-carbide-300r-case-review.html
http://www.legitreviews.com/article/1884/1/
The only cable I seem to have a problem with on PSUs is the 6/8-pin CPU connector it has to stretch over the graphics card unless you buy an extension cable and run it around the back nicely.. :) Something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=CB-066-AK
Here is my 1/2 pennies worth :D
Intel + AMD build:
YOUR BASKET
1 x MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard £77.38
1 x Sandisk Ultra SSD 120GB 2.5" SATA-2 Solid State Hard Drive - (SDSSDH-120G-G25) £69.95
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £68.99
1 x OCZ ZS Series 650W '80 Plus Bronze' Power Supply £59.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £52.99
1 x GeIL Enhance Corsa 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEC38GB1600C9DC) £39.95
1 x Samsung SH-S222BB/RSMS 22x DVD±RW SATA ReWriter (Black/Silver/Biege) - Retail £19.99
Total : £758.21 (includes shipping : £12.50).
Intel + Nvidia build
YOUR BASKET
1 x OcUK GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card £299.99
1 x Intel Core i5-3450 3.10GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £143.99
1 x MSI B75A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard £69.98
1 x BitFenix Merc Beta Gaming Case - Black £31.99
1 x Corsair Vengeance Low Profile 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML4GX3M2A1600C9) £25.99
1 x Samsung SH-D163C/BEBE SATA 16x DVD-ROM (Black) - OEM £14.99
Total : £799.96 (includes shipping : £11.75).
As stated by previous posters have not added a 3rd party cooler as using reference cooler.
Regards.
C.
By the way, how do I create a list like you guys are? Is there a way to copy a forum compatible post with the list of linked components or do you just spend ages linking things in?!
The Z9 plus has that extension cable included and the OP doesn't get free P&P :(
It's tit4tat really, you can add a card reader with USB3 to the front of the Z9 for £10ish. If the OP prefers the Corsair case that's fair enough. I use the Z9 myself and i know it cools well and does a lot for the price, it's why i recommend it.
The OP did ask for the ability to dual card the GPU. The mATX mobo you are spec'ing doesn't do Xfire properly and even if it did the cards would be very cramped together (HOT), not to mention being a smaller board he loses PCI slots (upgrade potential).
Why do you think the D3H won't perform with Crossfire very well?
I lived in Lincoln for a good couple of years with my ex and I have family in cleethorpes.....it's a small world :)
Indeed! I have been sunning it up with the other half today on the beach in Clee. ;)
Ahh, didn't know that bit! Sorry. Yeah if you want CF I wouldn't bother with that mobo then.. :p
I do think these things through buddy lol
Ceuotc made the same mistake. Also the SSD he is spec'ing, is half the speed of the M4 I spec'd. We also like to recommend low profile RAM not aggressive heatsinks which just get in the way :)
P.S Hey Beej
P.S Hey Beej
Hey Hono :)
Spec in post #18 looks pretty good to be fair - and Hono has explained most other options quite well :) If you want modular I'd suggest this as it actually has more on the 12V rail than the 600W Coolermaster:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-058-OC&groupid=701&catid=123&subcat=1098
Thanks to everyone for all the help. I think I'm gonna go for it tomorrow and order some bits :). It is indeed a small world, Lincoln, nobody knows where Lincoln is!
I think I'm gonna go with a lot of what hobo suggested :) I'll post a final spec before I order.
Night.
Night.
Ohhh but I do! Whoever called Chicago the windy city clearly never visited Lincoln lol
For the record I moved away just over a year ago, I found another home so I'm not a hobo ;)
Right, i had a few bevies last night and have been a bit worse for wear today :P Finally got round to some finalizing.
To recap, im most likely going to xfire the 7850s eventually, i have a hard drive and Dvd rw which i can take out of my current rig.
Im just checking that its all good to go, enough juice in the psu and theres nothing more i need in terms of cables extensions etc. Any other comments would be also appreciated. Is there any deals on that i have missed.
You may also be getting a few posts on here when it comes to building it, because it will be my first time. :P although to be honest i think that may only be connecting everything in the final stages.
Anyway i'm pretty close to ordering, i have used that little bookmark tool and this is what i have got.
YOUR BASKET
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £104.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £88.99
1 x Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £25.99
1 x OcUK Black Gaming Keyboard (5105GU) £10.99
Total : £760.91 (includes shipping : £12.50).
