So is there anyone actually playing, or are the servers defiantly down? Wondering if it's worth carrying on hitting CTRL+V and Enter.
Error 37 indicates that the authentication service (the step that verifies your username and password, and checks to see that you've agreed to the Terms of Use) for Diablo III is experiencing a high volume of traffic and cannot immediately process your login attempt.
Read the thread just after getting home from work. Thought it would be a massive downer.
Logged in first time though.AH is working flawlessly too.
[TW]Sponge;22034575 said:SFHBASIUFBNL!!!!
Well i finaly got 45 GBP to spend on this game, is it worth it in this state or shall i hold off for a bit longer till the problems get patched![]()
Completely worth it.Well i finaly got 45 GBP to spend on this game, is it worth it in this state or shall i hold off for a bit longer till the problems get patched![]()
