haha, what coolant and/or additives were you using?
Tasty!
Its back to the fact that tubing leaches and blocks clog becuase of this leaching effect and then the dye stains the plastersizer.
Yes probably plasticiser leach but as always its hard to tell, could be rubbish in the rad that wasn't quite flushed enough, happened to me twice now, last time it happened was a few years back when I switched to distilled + kill coil, but now that appears to be a big problem with ONE block manufacturers nickely plating processes![]()
i don't think distilled and silver is the holy grail of fluids that many seem to think.
100% agree.
not all its cracked up to be at all.
i have mayhems pure water and a few drops of biocide and its fine. but lets face it. every fluid combination on the planet has downsides.
Consider the modern day water cooling system a bit like alchemy and you probably as close as you gonna get. EC06 uses the same base as X1, Pastel, Aurora. If you had a sample of it i would love to get it from you for our own purposes though.
