To view actual boost in GPU-Z view the sensors tab, the card info tab only shows what the BIOS tells it too...
still don't fully understand this overclocking lol, gpu-z showing boost as 1154 yet evga precision is showing max as 1202mhz ive no idea if thats any good or not? Thats with the card set at +95mhz
Looking at the last post on page 1 by Kmax86 he has the same card as me and has set it to +100mhz the same as I have yet states a core speed of 1263mhz yet my max is 1202mhz?
using the info I mentioned above, he has set his at +100 so he's overclocked it himself, so his boost would be 1163, so if you added +100 to the core, you'd get 1302mhz
	snip
Why is it showing intel hd4000 graphics, instead of my gtx670?
Thats my 670 at +160mhz
because you're using the iGPU as well, probably with Lucid Virtu on?
A 670 wouldn't get anywhere near that score no matter the OC without it.
He doesn't have AA enabled which is why his score is high.
Reason its saying that is because he has intel graphics driver installed. Go to control panel and remove it.
