Good to know, thanks for the tips dave
Any other pointers? Not a complete newbie to GPU clocking, but a million miles away from competent![]()
I'll have to try TRIXX, but unsure if it would give me all the options AB does, with the card being MSI and the extra little options etc..only one way to find out I suppose.
Usually if I'm testing something on air that I know might get a little toasty the fan is 80% constant minimum or running a 1:1 profile.
Whats a good clockspeed/memory to aim for? The little time I've had for testing has given me 1200/1550 so far.
Does turning off ULPS help, dont know how to do it but believe it helps
When you had probs with AB did you press apply and clocks reverted to stock?
