In case anyone is having trouble with using Afterburner to overclock past the limits, have a look at this thread which tells you how to fix it:
http://forums.guru3d.com/showthread.php?t=359671
Short version: Download the two .dll files and modify two lines in the config files.
I did it and it works and lets you overclock way further than the usual Afterburner limits!
. Asic is 83%.
