Man of Honour
- 29 Mar 2003
- Blurton
What height are you for starters?
5' 6"
Inside leg up to my crotch = 30" or in French, 760mm
[DOD]Asprilla;22080895 said:So I open my PC and it appears someone is doing Edge 800s for £250. Well, it would have been a shame not to.....
5' 6"
I'd say really if a frames a little small it's less of an issue than if a frames a little too big
5' 6"
Good price. Where was that?
[DOD]Asprilla;22083760 said:Can't say; competitor.
However, it's the base pack so no HR band, no cadence monitor and no maps. I've already got the first two and I'm going to use Open Street Maps from TalkyToaster.
You can download the maps from Torrent.
[DOD]Asprilla;22083913 said:I know a man who knows a man who has a copy. Still going to use the OSM maps though.
It's from an electronics store. If you go a Google Shopping search for Garmin Edge 800 then it's the lowest priced one that has feedback (there are two cheaper, but I think they are ex-UK and so there will be VAT and Duty payable on top). £245.99 plus delivery.
Can anyone recommend me some good chain/component lube?
I initially bougt some Fenwicks for dry conditions, as I only intended to cycle to work when the weather was nice, but I've been commuting to work in every imaginable weather this year!
What I'm after is the best all around lube for all conditions, I'll keep the Fenwicks to my weekend/good weather bike!
Without seeing you it's hard since you might have some weird proportions.
Try this bike fit calculator.
Dont rush through it, take your time and get all the measurements properly, it can take 20-30 mins to work through them all. Get somebody to help you out if you can.
It will never be as good as an experienced fitter looking at you in person, but it might help steer you in the right direction.
Also, the geometry of the bike can make a difference as well. My last bike was about 5cm "too short" in the seat tube because it had a long top tube.
gah! riding to work today in the wind and the rain I've never been more tempted to buy a steel/chromo tourer or something like a Dawes Galaxy with mudguards!
been looking at old steel rodies but none of them have the room for mud guards I'd expect!
If you can fit a 5 mm Allen (Hex) key between your brakes and the tops of your front and rear tyres, and between the rear tyre and your seat tube, then the Road racers will fit your bike too. [PS I've since read that some people have struggled with the width of 28 mm tyres. I know that tyres up to 25 mm wide are definitely okay if your bike passed the clearance test]
