With the S3 I can mount the phone using Samba and then do stuff over Wireless-N which is even more convenient.
Thought ES File explorer could do all Samba can do and more?
Thought ES File explorer could do all Samba can do and more?![]()
AirDroid is what I've got installed but will try that tonight^
I find SwiFTP to be perfect for transferring files I already Know I want, Firefox has it saved already so it's just 2 clicks and I'm logged into the phone transferring files. With AirDroid and the like it's a bit clunkier than a simple FTP interface but is needed if you don't know the files you want and need thumbnails to guide you.
(For best performance IE is not recommended)
Do you prefer the White version of the Samsung Galaxy SIII?
Really impressed with the ease of the panoramic mode with the S3's camera. Had something similar previously on my old k850i but you had to allign it with an overlay of the previous image.
Did this in about 10 seconds:
https://www.dropbox.com/s/n1qtlt3se9f88dq/2012-06-12 15.19.25.jpg
You could just say you are in an exotic location you know.
Airdroid's benefit is that it can play videos in the browser directly from the phone, which is handy
Although those 1080p 30Mbit camcorder videos might want to be skipped ¬_¬
Again cannot do an OTA update unless you have stock recovery on the device. Use KIES or Odin.
Rock Case, genuine one of course. It feels amazing in the hand and the material/texture is excellent too. Looks nice too and feels like a part of the phone.
<SNIP>
Any type of USB mic? Only one I have is one from a Wii.
Update: It sees the USB being plugged in, but does not recognise it as a mic or audio device in any way and records through the internal mic.
Mic is a Logitech mic from Wii Games like X-Factor and U Sing.
I played an unconverted 1080p file from my DSLR (I think it's over 30Mbit) which I had copied on to the SD card. Worked perfectly
have you got the black or grey case?Rock Case, genuine one of course. It feels amazing in the hand and the material/texture is excellent too. Looks nice too and feels like a part of the phone.
