2011's Google IO reported hardware spec support for USB audio
AirDroid is what I've got installed but will try that tonight^
I find SwiFTP to be perfect for transferring files I already Know I want, Firefox has it saved already so it's just 2 clicks and I'm logged into the phone transferring files. With AirDroid and the like it's a bit clunkier than a simple FTP interface but is needed if you don't know the files you want and need thumbnails to guide you.
I just remembered. There is a video knocking around with a guy connecting loads of stuff to his SIII with an OTG cable. In that he uses a Fiio E7 USB Headphone amp - maybe it's audio out only and not audio recording devices?
Why use a browser for swiftp, just add the location under my computer.
Ah that's good to hear! I tried a few files that failed to render in the browser but they were h264 high profile videos and assumed the 30Mbit ones might fail too.
Sorry I just re-read your post. I didn't play them in the browser. I used MoboPlayer
That sound logical yeah, ah well it was worth a try at least!
I find the FTP client speed readings more accurate the Windows. That and you can queue up batch transfers. You can't queue stuff via Explorer.
Like I said, I have my reasons for using different apps to do different things. Convenience and efficiency are at the top of the list.
Hold volume up, home and power, then navigate the otions for a reset.
