- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
Well after the mass of delays from Samsung last time I have decided to wait it out on this deal until the stock was here and accounted for...
Well here it is!
128GB Samsung 830 series SSD for just £79.99inc (will be £89.99inc by Monday).
Check it out
Samsung 128GB SSD 830 Notebook/Apple Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC128N/EU) @ £89.99 inc VAT
Samsung’s fast random read speeds (up to 80,000 IOPS) maximize performance* when it matters most. A Samsung SSD is the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
Samsung SSDs are designed and build completely in-house. The Samsung SSD 830 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially- engineered wear-leveling and garbage collection algorithms.<br>
Use the wider image option when adding this feature. We would like to capture all of the data represented on this specific feature image. However, do not use this feature image in this document, use the actual image in images folder. Samsung’s 20-nanometer-class toggle DDR NAND Flash chips enable data transfer rates of up to 133 megabits per second (Mbps)-more than three times faster than conventional (40 Mbps) single-date-rate (SDR) NAND Flash chips.
While most SSD makers rely on generic, dual-core controllers, Samsung has developed its own proprietary, triple-core MCX controllers that excel in multi-tasking and help to assure stead performance over time. Based on an ARM9 controller, its three CPU cores can execute multiple instructions such reading data, writing data and optimization.
- Capcity: 128GB
- 256MB DDR2 Cache
- 3-Core ARM9 Risc MXC Controller
- Dimensions (LWH): 100 x 69.5 x 7 (mm)
- Samsung Toggle NAND
- Sequential Read: 520MB/s
- Sequential Write: 320MB/s
- 4K Random Read: 80,000 IOPS
- 4K Random Write: 30,000 IOPS
- Warranty: 3 years
- Norton Ghost
- SSD 2.5"-3.5" tray
Was £139.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Well here it is!
Check it out
- Capcity: 128GB
- 256MB DDR2 Cache
- Warranty: 3 years
- Norton Ghost
ORDER NOW
