Play dispatch confirmation!
...for Oceania - The Smashing PumpkinsI was excited for a second!
(well I am looking forward to the album, but you know...)
Amazon say they should have stock on the 16th, I'm thinking of changing to them, I would be right at the back of the pre-order queue though.
I have Light Flow Lite working OK with Handcent on my Galaxy Nexus.
Initially it wasn't working, but I ticked "Enable notifcation", "Alternate on monitoring" and "Alternate off monitoring", as well as disabling the stock SMS app and it is OK now.
Not sure why it wouldn't work on a SGS3?
Anyone got any tips on good battery life?
After 7.5 hours I'm at 50% with the majority of the battery just being the screen. Automatic brightness good or bad?
How can I justify having two phones? I'm trying to convince myself I need an S3 when I already have a Galaxy Note![]()
Go sms pro is a very good sms app, better than handcent as well IMO.
I think it allows you to change notification LED colours (not sure if this works on the GS 3 though), the notification LED works for me on my 1S.
What happened to "I could never go back to a smaller screen"?
I'd sell the Note and get the S3.
Keep the note as a dedicated Draw Something phone, use the S3 for everything else?
Yup, Go SMS Pro allows you to change the LED colour, I have it all setup and working perfectly.
Just seen those settings and then mention Handcent, have enabled and will now wait for a text
I'm seeing great results with my battery life, make sure nothing is constantly keeping your phone awake. I'm on about 75% after 7 hours with moderate daily use, Twitter syncing every 5mins, email etc all on push and full brightness. Screen time has only been about 45mins though.
Well the tracking finally updated, my S3 has been out for delivery since 8:03 this morning, had three texts to say phone is coming today, last one said it can be delivered up to 9pm tonight although I doubt it will. Good old Yodel![]()
Sounds familiar. I did ring cpw (they have a delivery option) and they can check with Yodel to confirm the delivery. It helped for me.
The screen isn't THAT much smaller really, but the overall package is so much better with all the software improvements, LED notification, camera speed etc.
I'm surprised you haven't got one yet, or have you?
My Pebble Blue has just arrived and I’m not sure if I like the colour
Don’t like the white, so doesn’t leave me with much![]()
Pick the lesser of the two evils.![]()
