yesStock ROM?
Stock ROM? I've not noticed any untouchable screen areas really, would have been easy to notice as I use quick controls in ICS Browser+!
snip
A fair few Blue one's coming through now - Any white owners getting buyers remorse....![]()
All fair enough, but so far, from all of the battery reports coming in, it seems that under similar usage you'll get similar battery life. Which is very good considering the screen difference.
Of course that could be wrong, people have a habit of doing things to maximise the battery life to make it look better than it actually is, for some odd reason.![]()
Is there even going to be an extended battery? The design of the phone doesn't necessarily lend itself well to having an extended battery like the GS2 did (with the lip).
Patiently waiting for an ICS theme for OMEGA 5.1 and then I'm probably sorted ROM wise. Will just keep an eye on mods after that point!
do you not use appbrain any more?
Damn! Can no longer "stalk" you to see what apps you have installed etc............. ¬_¬
Or maybe you've regretted waiting...
