***The Official Samsung Galaxy S III Thread***
Just to clarify then, I did browse the Internet for around an hour, but around 45 mins in that pdf viewer started using cpu aswell.
Just done a hour worth of browsing there. Was mostly just browsing this forum and XDA, brightness was set to 50% (think my eye sight has gone down the drain now! 50% way too bright at night time!!!!! :p). Just had the usual running in the backgroud, messages, gmail, whatsapp etc.
So, not much difference at all really :)
Although the S screen used a xxxx load more power than the GS 3 screen :p
And your browser used a fair bit more power than my browser :p
EDIT:
Just realised we should have compared the amount of data dll and uploaded as well :o
EDIT 2:
And also just realised that we both didn't take screen shots of the browser time for activity..................:o :o :o
Damn! :p
When you turn the phone on its side, the screen rotates (as it should) but then jumps to the 2nd screen. Turning off auto rotate fixes this but then using boat browser the phone locks in portrait mode and there's no way of using landscape mode. Is there a way of fixing this ??
Hmm, it seems my notification bar has gone ****s up. It now fails to display any new SMS or Screebl notificatoins, and instead has only a single icon that is there all the time that is kind of a grey box with one side pointly (like a house put on its side) and a minus symbol or dash in the middle. Restart doesnt fix it. Stock ROM.
HDTV Adapter - Model:EPL-3FHUBEGSTD. The power lead is the S3's own microUSB charge cable.
As for your second question, check this out and you'll also see the TV widget in use later on in the video.
http://www.youtube.com/watch?v=46IiRyigUH0
I want a MHL adapter now and I don't even think I would use it. :D
That's just badass connectivity!
Shame it's only HDMI, would a HDMI > DVI converter work? (No sound obviously)
ever since i updated to new firmware its been mucking around
when the phone rings the screen stays blank for a few seconds,
when i get a text message it will vibrate for longer....
going to try a reset and update now but has anyone had the same issues?
