Yeah, 4.8 seems pretty doable on 1.2V for me.
IBT very high temps averaged out around 86. One core peaked at 91.
Max temp hottest core reached was 87 in prime.
Think I will settle there, do more stability testing, and one day a year or so from now, remove the IHS, and see where I can get around 1.45V![]()
Screenshots please
Seems you have the worlds best IB cpu and not a single screenshot of some stability testing!
	Edit: changed to link as screen in next post better
http://i785.photobucket.com/albums/yy134/chris_rabe/48at1216V.png
All my testing above was with the samsung greens at stock.
With the memory upped to 2000 at 10-10-10-28-1t I get 110 gflops or so.
But I have still not figured out how to get the memory fully stable at those clocks.
About to go back into BIOS and fiddle with just about every timing, using a guide on the asus rog forums to find my way through.
-Mike-, sorry if I came across as aggressive or anything. Woke up badly this morning
With regards to settings, I will need to take notes, but nothing is set to extremes.
internal pll overvoltage disabled
epu power disabled
Phase control is optimised
llc is ultra high
using offset voltage of around 0.06
pll auto, so around 1.8
spread spectrum disabled
that was under load in IBT. Would vary from 1.192V to 1.208V, usually 1.2V
Under load in prime it will be anywhere from 1.2V to 1.232V, usually around 1.216V.
Either way, even if I still only need to nudge it up a bit, it's still a pretty decent chip i'd say![]()
Congrats, looks like you got an awesome chip there!
